Chasing something invisible. . .
0 Members and 1 Guest are viewing this topic. Read 3743 times.
Hantra
« Reply #20 on: 31 Jan 2005, 04:23 pm »
Quote from: zybar
B,
With the Tact pieces of the music I was missing are now there to hear.  The cool thing with the Tact is that if you feel like something is missing, you can create a curve or correction that addresses it.
I am super happy with the Tact and will not go back to a non-corrected system.
George
Thanks G:
Are you using it in analog mode?  Like as a preamp?
I'm just feeling some subtractive effects from the DRC program, and it may be more "flat", but I am not sure it's better in some respects.  Problem is, I can't play with the curves and stuff, as this is one very complicated 52 step procedure that involves convolving and then creating a filter with a batch file.
Nevertheless, it's encouraging.  I will have to keep tweaking.  I am a bit concerned b/c I know my tweeters go to 60K, and even though there isn't anything there really, perhaps any type of correction to 20K or 21K will have a negative impact on this area. . .
B
Hantra
« Reply #21 on: 2 Feb 2005, 12:09 am »
OMFG!  Please disregard this ENTIRE thread!
I swear.  .  .  Last night after I measured, and found that my freaking Lynx card was malfunctioning, I plugged it back in single-ended, and the damned bass came back.  Not only that, but A LOT of stuff came back.  So this was my problem all along.
Sometimes PC based audio is like VINYL in more ways than one. :lol:
:stupid:
ted_b
« Reply #22 on: 2 Feb 2005, 12:14 am »
Ain't it grand, though? :)
I know , at first you're pissed because of all the time wasted...but it's great to find out the solution didn't require lots of $$ and therapy!!
Don't worry, though, B, I once went over to a friend's house because they couldn't get their turntable working......It was unplugged from the wall.
 :o
Ted
Hantra
« Reply #23 on: 2 Feb 2005, 12:21 am »
Quote from: ted_b
 :o
Ted
Ted, you should charge for audio therapy!  Thanks for making me see the bright side. .  I was pissed. . But now I am just soaking up this Steve Kimock that I have been DYING to hear properly.  Whew!
Thanks again. . .
B
