Spatial Audio - New X Class Product Announcement
0 Members and 2 Guests are viewing this topic. Read 65209 times.
Spatial Audio
Re: Spatial Audio - New X Class Product Announcement
« Reply #60 on: 31 Mar 2019, 01:04 am »
Would agree I could lose the sub?
That could free up some funds by selling it.
That’s the last question! Thank you.
For sure - you could lose the sub, and get much faster bass in the process.
Clayton
« Reply #61 on: 31 Mar 2019, 01:13 am »
Dual 15's in a powered OB setup.  Yeah that's gonna crush any sub out there for speed, detail, punch, and overall realistic sound.
If you're doing action movies at reference levels, you might need a sub for the 20hz stuff.  In every other area the OB setup will be superior.  IME.
sumoking
« Reply #62 on: 31 Mar 2019, 02:56 am »
Thanks Clayton.. yes, that will work!
Will help pay for speakers as well.
Looking forward to seeing the veneer version
in order to make a decision.
kimmki
« Reply #63 on: 1 Apr 2019, 05:14 am »
Spatial Audio X5
Is it possible to ship to Korea, Republic of (Zip Code 21397)?
If possible, I'd like to know how to buy it and how to deliver it.
Spatial Audio
« Reply #64 on: 1 Apr 2019, 04:46 pm »
Spatial Audio X5
Hello kimmki - Yes we ship worldwide. Please email me directly at [email protected] with your complete address and I can obtain a freight quote for you.
Clayton Shaw
www.spatialaudio.us
bbybaudio
« Reply #65 on: 5 Apr 2019, 06:20 pm »
Great info on X3 and X5. Will the X5 be adequate for a 20 X 15 X 9 room or should I be looking at the X3?
Spatial Audio
« Reply #66 on: 5 Apr 2019, 09:48 pm »
Thanks - yeah, I think the smaller X5 should work in that room, which is a medium sized room, so you should be good to go.
Clayton
Spatial Audio
« Reply #67 on: 17 Apr 2019, 02:37 pm »
Here is the production X3. The baffle is a solid wood composite system that is rock solid:
Video Interview with Dan Wright about our Axpona Room 510:
https://youtu.be/8kyGGzFc9io
Clayton
« Last Edit: 27 Apr 2019, 08:16 am by Spatial Audio »
Wind Chaser
« Reply #68 on: 17 Apr 2019, 05:19 pm »
Very nice! What do they look like on the back side, and are the amps integrated on the chassis or do they stand alone?
Spatial Audio
« Reply #69 on: 17 Apr 2019, 06:06 pm »
Thanks - I will post a rear pic as soon as I get it. The amp mounts horizontally at the bottom. The cast frame drivers are very nice cosmetically.
Clayton
KLH007
« Reply #70 on: 17 Apr 2019, 09:19 pm »
The wood laminate baffle looks great Clayton, and the legs are cool looking, sweet choices.
Spatial Audio
« Reply #71 on: 17 Apr 2019, 09:54 pm »
Thanks - but it is a true solid wood baffle of 2.3 inch thickness, not a laminate surface over some material. So sonic performance is excellent.
Clayton
hmen
« Reply #72 on: 18 Apr 2019, 03:35 am »
Clayton,
Looks incredible. Have you decided what veneer choices you’ll offer?
Howard
KLH007
« Reply #73 on: 18 Apr 2019, 03:48 am »
Howard, As I saw in Chicago the solid wood baffle Clayton chose seems to be 1/8th" slices of wood bonded together to form a 2.3" thick solid wood piece. I'm not sure it is a viable substrate for veneer, but the sample I saw looked awesome just as is.
Ekmanc
« Reply #74 on: 18 Apr 2019, 04:11 am »
The X5s look excellent, I can't wait to hear them!
coldfogey
« Reply #75 on: 19 Apr 2019, 07:17 pm »
I am using my M3 triode master in a finished basement.  40 feet long, where the speakers are located it is 18 feet wide and 7 feet high.  I know it
sounds like it is a huge room.  Any serious listening is done in the near field, 9 feet or closer. Can I get by with the X5?  I have no problem with my
M3  Triode masters, the sound is awesome.  One more question.  The Triode Masters were created to overcome some phase problems when using
tubed equipment.  I have some tubed equipment.  Is this new design compatible with both tube and solid state Amps?
yakbob
« Reply #76 on: 24 Apr 2019, 01:12 pm »
The X3 looks so amazing in wood and polished stands. Will the X5 feature the same build type, or will it look more like the mechanical drawings shared earlier and in a paint-only finish?
Spatial Audio
« Reply #77 on: 24 Apr 2019, 11:09 pm »
I would recommend the X3 rather than the X5 in such a large room - that is a lot of cubic volume to pressurize.
Yes, the new models are compatible with tube amps which normally have much higher output impedance than solid state amps.
Clayton
Spatial Audio Lab
Spatial Audio
« Reply #78 on: 24 Apr 2019, 11:11 pm »
Yes, the X5 will look just like the X3 - same quality and materials, but with a 12 inch woofer.
I will post a picture tomorrow.
Clayton
Spatial Audio Lab
KLH007
« Reply #79 on: 24 Apr 2019, 11:15 pm »
The X-3s in the solid wood look awesome!
