Groneberg power cords
0 Members and 1 Guest are viewing this topic. Read 6384 times.
corwin99
« Reply #20 on: 29 Jan 2005, 08:58 am »
If anyone is interested, i have 4 of those Schurter IECs in Eduardo's pics that i'd sell for really cheap. They don't have that Rubber part anymore, i threw that part out since it was too small for any of my cable (12AWGx3)... and one of them has the plastic screwdown part removed as well.
Eduardo AAVM
« Reply #21 on: 29 Jan 2005, 06:11 pm »
You are right the rubber limits the cable diameter you can use, what I do is to cut the rubber as it approaches the connector the  rubber inlet diameter is wider.
You can see the cut in the picture.
Regards.
Christophe35
« Reply #22 on: 31 Jan 2005, 12:07 pm »
I built 2 groneberg power cords, they are plugged to my monos since a couple of days. Make a big difference. Im my opinion, the stock power cords doesn't allow to hear  the real potential of the monos. They perform much better now.
About the groneberg cables, I didn't like them for speaker cable but found them very good for IC and power cords.
Christophe
Christophe35
« Reply #23 on: 18 Feb 2005, 07:28 pm »
I changed the stock power cord of my njoe tjoeb to groneberg, that makes a big difference. The sound is more dynamic, more lively. Soundstage is bigger also.
Christophe
