Hello Witchdoctor, thank you for your report about the Powergate,I've been searching and searching to no avail, about the class D amp used on this amp. There is a review that shows the innards of the system, showing in detail the power section and the amp section, but I cannot locate the amp details.https://i1.wp.com/blog.son-video.com/wp-content/uploads/2017/01/Powergate-Generale-02.jpg?ssl=1Do you have an idea of what type of amp is used? It should be a moderately decent chip, based on the $499 initial price tag.Thank you for your help.
IDK the chip used,if I find out I'll post.
Based on your comments and appreciation of the sound quality, the Powergate should have decent specs, specially for a $499 list product. The fact that they are selling the Powergate at $150 I suppose is because the problems and returns they probably had with the old firmware.The same have happened with other products from defunct companies. I appreciate your comments and now I'm looking forward to buy one. If you have more comments about the sound quality, I'd appreciate if you can share them with us.
I will be getting a PowerGate next week to power a set of Proac Studio 3’s. Same drivers as ATC scm 50’s. I will post my impressions once I spend some time with it.
Order the Powergate , Will arrive Monday , My uncle ordered one as well . Will report back
My Powergate arrived Friday, within 36 hours of my order - nice.I am using it at my desk, USB audio via PC with Foobar. Connection and playback was simple. Sound through the speakers is good, nothing spectacular, but more than adequate for the task. Difference between a 24/192 FLAC file and a 320 MP3 file is apparent, but not substantial.The headphone playback on the unit is nothing special. Fortunately, the Powergate has a pre-out should I decide a separate headphone amp is necessary.I've failed after an hour of attempts to get the Klipsch App on my Android phone to connect to the unit. Once in a while, it says it connects to the Play-Fi unit, but before I can get the Wi-Fi password entered, it loses the connection. That's happened 5-6 times. The phone will see it, but lose it before the next step. Frustrating. I'll try again later.Pretty handy little unit. Not an audiophile product, but definitely a nice swiss army knife.
I am using it at my desk, USB audio via PC with Foobar. Connection and playback was simple. Sound through the speakers is good, nothing spectacular, but more than adequate for the task. Difference between a 24/192 FLAC file and a 320 MP3 file is apparent, but not substantial.Pretty handy little unit. Not an audiophile product, but definitely a nice swiss army knife.
Try holding down the wifi button the back for around 8 seconds, the light needs to be pulsing slowly to connect. Remember to get both the Klipsch stream app and the Utility app to run the firmware updates.
You need to move the device next to your wifi router when you are updating firmware with the playfi app. Move it next to the router and try again.
Thanks, here's what I get....Power on, hold down Wi-Fi Setup button for 8+ seconds (until I hear 2nd chime). App searches for device. Says 1 Play-Fi found. Click on Set-Up. Enter Wi-Fi password. Says attempting to connect. Says "completed Set-Up"...and then immediately goes into search for device mode again. Comes back with "Devices Not Found".
That's the chip used on the Powergate Max. I doubt they used it on the Powergate. But if yes, then the Powergate is the steal of the year.I also doubt that they used an ICE module, I don't see traces of it on the pic I linked.I hope somebody can tell us.
