Adding a Sub Out to a diy Tube Amp Project
0 Members and 1 Guest are viewing this topic. Read 1100 times.
Ericus Rex
« on: 24 Feb 2019, 03:28 pm »
Hi folks!
I'm building a hard-wired Jonokuchi integrated amp (http://www.pmillett.com/jonokuchi.htm) and would like to add a sub out to the circuit. I want a full-range, summed L+R, variable (effected by volume control), pre-out (not amplified).  Is this as simple as tapping off the volume pot outs and splicing L&R at the RCA jack?  Or would I run into feedback or L/R bleed-through issues?  How do I add this?
poseidonsvoice
    • 2 channel/7 channel setup
Re: Adding a Sub Out to a diy Tube Amp Project
« Reply #1 on: 24 Feb 2019, 04:23 pm »
As you suspect. It isn’t straightforward.
See here:
https://www.rane.com/note109.html
And here:
https://www.diyaudio.com/forums/analog-line-level/281509-passive-summing-subwoofer-signal-using-resistors.html
In your particular case, you most definitely have to make sure that the input impedance of your subwoofer plate amp is nice and high since you now have introduced a variable output impedance by insisting on using your volume control. This is a low current, low level signal. So you will probably  have impedance issues particularly at longer interconnect lengths.
An opamp would be a more elegant application here, particularly an instrument amplifier design like the AMB alpha 24.
I’ll be curious to know how you solve your conundrum with a passive analog discrete solution. Even using a transformer would be a challenge. I personally vote for an active circuit!  :thumb:
Best,
Anand.
Ericus Rex
« Reply #2 on: 1 Mar 2019, 09:15 pm »
Excellent!  Thank you for the links and info, Anand!  I can handle three resistors so I'll try that route first.
Many thanks again.
