Seagate 5 TB Internal Hard Drive For Bryston BDP-3 Digital Player - Review
JohnR
Well that's progress at least :thumb:
zoom25
Yeah, the 2TB Passport is synced with the BDP-1 and the hibernation feature is still working fine.
The NAS and hard drive does become active and spin up a few times throughout the day and then goes to sleep. My next plan was to put a small SSD inside the DS119J for added silence and continue with the music on the My Passport since they are barely audible in a silent room, but it looks like that's not possible. Not a big deal at all. Playback from NAS is great and without any performance issues. It does sound a bit different than playback from the USB portable drive plugged into the BDP-1. It took a bit getting used to. I can go louder with the NAS and was turning it up more throughout. Initially, it felt as if the weight and immediacy of the music had gone down. But that just might be because it doesn't stress on transients. As I'm getting used it, I'm liking it more and more each day. It's easier on the ears.
JohnR
I imagine you just need an adapter bracket like this (never used one myself):
https://www.newegg.com/Product/Product.aspx?Item=N82E16817979016
zoom25
I found the adapter for 2.5" drives. If you search for "synology disk holder type c" you'll find this L shaped part that works. That's not the issue. The issue the rep guy online told me was that under the specifications page for DS119J, they list only support for 3.5" and 2.5" SATA HDD, not SSD:
https://www.synology.com/en-global/products/DS119j#specs
Other products like even the DS218J lists support for both 2.5/3.5" SATA HDD and 2.5" SSD:
https://www.synology.com/en-global/products/DS218j#specs
I asked him why DS119J doesn't support SSD and he wasn't sure. :scratch:
I'm not sure if this is a case of it won't work plain and simple or if its not recommended in certain configurations?  :scratch:
JohnR
My guess is they haven't gotten around to qualifying them yet.
Still, it seems to me that the simplest solution to the noise would be to put it in another room.
