Please Recommend Interconnect for a High End Tube Amp.
A_shah
Hello,
I am looking to get IC for QuickSliver Tube amp. Any recommendations would be appreciated :scratch:
thank you !
Asghar
all power  outlets are PS audio outlets &  PS audio Dectet and noise harvesters in pairs .
Headphone Gear
1. Gungnir DAC
2. Mojo (Hp)SS
3. Audeze Deck ard( HP)SS
4. QS Tube HP.
« Last Edit: 9 Feb 2019, 05:29 pm by A_shah »
witchdoctor
Re: Please Recommend Interconnect for a High End Tube Amp.
« Reply #1 on: 9 Feb 2019, 02:24 pm »
Hello,
thank you !
Asghar
Headphone Gear
1. Gungnir DAC
2. Mojo (Hp)SS
4. QS Tube HP.
I like the Mogami Gold which is used in the majority of recording studios. I also like Mapleshade a lot. Both are good value without crazy $$$ and very transparent.
I would also HIGHLY recommend trying the Mapleshade wall outlet to plug your gear into.
https://www.amazon.com/Mogami-GOLD-RCA-RCA-03-Contacts-Connectors/dp/B015NQGILK/ref=sr_1_1_sspa?keywords=mogami+gold+rca&qid=1549722195&s=gateway&sr=8-1-spons&psc=1&smid=A1NKUZPDBQC7DX
https://shop.mapleshadestore.com/Analog-Interconnects/products/87/
ricmon
« Reply #2 on: 11 Feb 2019, 07:05 pm »
Ditto on the Mogami IC's.  I use them on my TT.
Ric
Chris Adams
« Reply #3 on: 11 Feb 2019, 07:28 pm »
Try these: http://audioenvy.com/product/home-car-pro-interconnects/nv-4s-pr-rca/
I just swapped out two sets of cables worth a little over 2k for these and I am blown away. They are effortless, clear, and fast. I have a pair of Quicksilver Mid Monos and an LTA Microzotl preamp.
They are returnable if you don't like them.
A_shah
« Reply #4 on: 11 Feb 2019, 07:58 pm »
These look interesting
Asghar
dspringham
« Reply #5 on: 24 Feb 2019, 06:17 pm »
Chris, are these particular (Studio - Prestige) cables available in XLR format?
Are you using their speaker cables and power cables as well? Any Feedback you would care to share?
Dave
Chris Adams
« Reply #6 on: 24 Feb 2019, 08:46 pm »
Dave
This is what you want: http://audioenvy.com/product/monitor/onestian-matched-pair/
I bought a complete loom, interconnects, speaker cable, and power cords. My system sounds so much more open, clear, and fast, not harsh, I just can't believe it. Not that what I had was bad, not at all. When I replaced two pair of interconnects and heard the difference, I ordered a replacement for every cable I had.
Clsmooth391
« Reply #7 on: 14 May 2019, 04:01 am »
The Grover Huffman Pharaoh interconnects are the best I have tried. I've had the Teo Audio GameChanger Jnr and Cardas Clear.
ketcham
« Reply #8 on: 14 May 2019, 09:35 pm »
Zenwave D4/D5 series. (unshielded vs shielded)
Allnic ZL Technology Mu7R series
« Reply #9 on: 26 May 2019, 02:49 pm »
Headphones cables most be balanced, the sound quality is much better than the one (-) pole banana plug.
An audiophile suggestion:
http://apuresound.com/v3.html
An DIY suggestion:
Neotec UPOCC Teflon copper wire awg 20 + Neutric 4 pins XLR
« Last Edit: 27 May 2019, 05:55 am by FullRangeMan »
navi
« Reply #10 on: 27 May 2019, 03:10 am »
Hello,
thank you !
Asghar
Headphone Gear
1. Gungnir DAC
2. Mojo (Hp)SS
4. QS Tube HP.
Van Damme LoCap55 (best)  or their coaxial mic cable
Jon L
« Reply #11 on: 27 May 2019, 03:28 pm »
Their "back story" was an interesting read, and I really like their RCA connector design.
Usually, IME, cables that utilize low-mass, low-capacitance design tend to sound fast, airy, smooth but often not warm and dense.  How's that aspect of these Audio Envy cables?
Chris Adams
« Reply #12 on: 27 May 2019, 07:26 pm »
I wouldn't call them warm and dense. However, I don't find them cool and thin. Of all the ICs I've tried/made, including some in the four figure range, these allowed the essence of each piece of gear upstream to flow unimpeded.
SET Man
« Reply #13 on: 27 May 2019, 08:54 pm »
Hey!
    Those look very good, especially for the price I must say. Look like a simple no nonsense cable.
   A cheaper option than that would be to DIY. I actually built all the cables in my system myself... well, except the phono cable for my SME 3009 II improved tone arm. Funny how I ended up with a low capacitance cables that sounds similar to description of the one shown in the link with 6N OCC copper litz conductors 26ga if I remembered correctly, adhesive teflon tape and Eichmanna Bullet RCA plugs. These work and sound great in my all tubed system with SET amps. I got tired of paying so much money for cables.
   Anyway, to A_shah... don't go crazy over this and look for seller with full refund return policy so you get to try them in your own system.
Buddy
Elizabeth
« Reply #14 on: 27 May 2019, 09:24 pm »
One minor problem is no price range from the op.
As far as suggestions, each poster is going to off his or her own fav cable.
So I an NOT going to suggest any cable in particular. Just lend my bias to well known major market cable makers.
Audio Quest
Cardas
Kimber
And if you buy used... be aware a LOT of fake cables out there.
« Reply #15 on: 28 May 2019, 09:21 am »
I have two copper/silver cables very well made by HifiMan site, both are inexpensive and good looking.
ric
« Reply #16 on: 28 May 2019, 01:37 pm »
Hi, I would recommend trying the Schroeder method, which is using a T or Y splitter to allow two sets of interconnects. You can buy a cheap pair of splitters on Ebay and if you hear a difference, get better quality splitters (I'm using some older Monster solid brass).
This is if you have two pair of ANY type of IC's. I used what I have on hand and the difference in sound quality is huge. I know it sounds nuts, but it works and doesn't cost much to implement. You can google Doug Schroeder method for more info....
