I stumbled across the fact that the Gate can support a usb to ethernet adapter. I had an old Dlink adapter plugged it in and applied power to the Gate. Lights started flashing and behold a hardwired connection (confirmed via router). A little investigating also turned up the fact that Phorus is selling a DTS Play-Fi adapter themselves.https://www.amazon.com/DTS-Play-Fi-USB-Ethernet-Adapter/dp/B07CNBWKM9/ref=sr_1_fkmrnull_5?keywords=phorus+usb+ethernet&qid=1551474349&s=gateway&sr=8-5-fkmrnullI already have ethernet outlets in most places so this is great for me, plus it lets me re-use otherwise obsolete hardware.
Other than allowing uninterrupted playback of 192/24 Flac files it didn't affect the sound quality.PS. I registered in 2012 so I do a lot of lurking and very little posting.
Witchdoctor,Do you think the Gate/Powergate could be a good solution for me?Let me explain: in my HT I would connect it to my oppo 105 rear surround audio outputs in order to wirelessly transmit the signal to a Powergate connected to a pair of rear speakers. I realize this is not what Klipsch had in mind in terms of primary usage, but considering I don't want to deal with a bulky receiver this could hopefully prove to be satisfactory. Cheers,David
gwing, you are using the USB port that supposedly (according to manual) is only for service/firmware updates, right?munosmario
If I’m not mistaken you can update the Gate wirelessly via the Klipsch Utility app. It worked great for me.Brett
Sorry for the late reply, yes the usb port on the Gate. Unplug the Gate, plug in the usb to ethernet adapter & cable then power up. Works if the WiFi is setup prior to this or not. Also used this adapter https://www.amazon.com/gp/product/B00MYT481C/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1. Somewhat cheaper than the Phorus adapter. Someone on the web noted that if it works with a wii or wii-u then it will work, just took a chance that most companies didn't stray too far from the DTS Play-Fi basic design. I have 4 Gates (three on usb-ethernet adapters), a PowerGate & a Phorus PR5 which isn't as nice as the Klipsch boxes but was a bit cheaper, it was relegated to the garage So far everything has worked well although I have been getting the most use out of running the output of iTunes on my server out to the line in on a Gate and then sending that everywhere. Playlist management is alot easier and it's easy to control with the iTunes remote app.
purchased this thanks for the info!not that it is on ethernet, it doesn't show up in the app. how do you sent music to it?thanks in advance
I have to say I am loving this device. I just got mine hooked up a few days ago and did the firmware update. I signed up for a 30 trial with Qobuz and I am very impressed by the sound quality. I was previously using a Chromecast Audio with the optical out into my HK3490 receiver and with the Gate's 3.5mm into RCA's the soundstage is deeper and wider. I'm sure Qobuz's high quality stream helps too.Getting the firmware updated was a little tricky.- I couldn't time the power cord insertion with depressing the power button on time so it was a little tricky to get it into update mode, but once in update mode I had no problems.Also, when using Qobuz the Play-Fi software hides the critical listening mode option on my iPhone. But my work around to that has been start streaming Spotify and turn on critical listening mode - then using the Play-Fi software start the Qobuz stream. And then I get a message on my phone that the Qobuz content is authorized to stream at that resolution on this device but using my ears I'm guessing that message is incorrect because the sound is wonderful and sounds like hi-res to me. Hopefully in the next update they will get this ironed out. Or maybe I'm doing something wrong?
First watch this and update the firm ware:https://www.youtube.com/watch?v=0Eok_GjgfZwThen watch this to learn how to use the app:https://www.youtube.com/watch?v=TqNTCHKiongOK?
but when i connect the usb/ethernet adapter it doesn't show in the app anymorewondering how i to play over the ethernet?
My Powergate dropped once and I rebooted the router, then the powergate, then it turned up in the app. If that doesn't work try klipsch support, they are pretty good
