0 Members and 1 Guest are viewing this topic. Read 6895 times.
Go with Rythmik Audio and use dual subs for 2-channel audio, too. If clean bass is what you want, that's precisely what you'll get.
Any advice on choosing a subwoofer?
Based on what criteria? SPL? Furniture grade? Musical prowess? Depth Charge prowess?But, yeah, buying more than one is the way to bless, I think. Something like the Kinesis Swarm but with lots more power would be fun.Also, have you perused data-bass.com?
Any advice on choosing a subwoofer? The two that I am considering are the SVS PB16-Ultra ($2500) ://www.svsound.com/pages/16-ultra-series or the RYTHMIC G25HP Direct Servo subwoofer ($2300) http://www.rythmikaudio.com/G25HP.html. I want as clean as bass as possible. No bloat. I will use two of them whichever I choose
SPL-:110dB at listening position with less than 10%THD
Most would advice going sealed for music (ported for AV) and Rythmik over SVS. Like others, recommend multiple smaller subs to fewer bigger ones. I run (3) 10 inch subs in an 8ft x 13ft x 21ft dedicated music room. Not super loud, but plenty for my old ears.
