*SOLD* Outlaw ICBM-1 Bass Management System
0 Members and 1 Guest are viewing this topic. Read 904 times.
sean619
« on: 3 Feb 2019, 09:35 am »
This ICBM Integrated Controlled Bass Manager is in like new condition (9/10).
It has been in my closet for a number of years as I no longer have a use for it. I used it between my preamp and power amp to take the bass load off of my monitors and onto my sub. It did a wonderful job for that purpose. It can do a lot more of course, but that was my use.
Includes: Original A/C adapter, Factory box & packaging
I will cover the Paypal fees.
Audiogon user: seanheis1
Price: $249
Will Ship to US and Canada. Can also do local sale in Seattle area.
Thanks for looking!
Owner’s Manual: http://pdf.outlawaudio.com/outlaw/docs/icbm_manual.pdf
Review Links: https://www.outlawaudio.com/reviews/reviews_icbm.html
SPECS:
Inputs
All unbalanced, -10 dBV, chassis-mounted RCA jacks Left, center, right, left surround, right surround, center surround (SR6), LFE
Outputs
All unbalanced, -10 dBV, chassis-mounted RCA jacks Left, center, right, left surround, right surround, center surround (SR6), left subwoofer, and right subwoofer
Controls
Crossover frequency selectors for left/right front, center, left/right surround, center surround (SR6); potentiometer controls for LFE mix and subwoofer level; switches for L/R recombine, subwoofer mono/stereo, and low pass special/ normal.
Crossover frequencies: 40, 60, 80, 100, 120 Hz, and bypass
Filter slopes: 2nd -order Butterworth high-pass in both "normal" and "special" modes 2nd order Butterworth low-pass in "normal" mode; 6 th -order Butterworth low-pass in "special" mode
LFE mix range: 0 dB (unity gain) to ¬10 dB
Subwoofer level control range: Full attenuation to +9 dB
Signal-to-noise ratio (A-weighted): 105 dB
Total harmonic distortion: plus noise less than .015 %
Relative phase shift channel to channel: less than 1degree
Relative phase shift low-pass output to high-pass output: less than 1 degree
Maximum input voltage: 4.5Vrms
Maximum output voltage: 9.5Vrms
Gain: 0dB (unity)
Power supply (AC adapter supplied): 15VAC -300mA
Dimensions: 44 x 440 x 175 mm (HxWxD) 1.76 x 17.6 x 7 in. (HxWxD)
« Last Edit: 25 Feb 2019, 02:23 am by sean619 »
sean619
sean619
sean619
