....Stupid question... would solid state be better for long-term storage than HDD? No moving parts seems safer now that I think about it. Once they’re offsite, I doubt they’ll get much use. It’ll be like an old box of negatives ...
I did some research on longevity not too long ago.https://www.pcworld.com/article/2984597/storage/hard-core-data-preservation-the-best-media-and-methods-for-archiving-your-data.html"...there are optical discs that are unquestionably the hardiest, handiest archival media available to consumers. Write-once BD-R HTL (High To Low) can last for 100 to 150 years given a relatively mild environment—i.e., not on your dashboard in Phoenix. Milleniatta’s M-Disc BD-R and DVD+R write-once discs use an even more stable data layer that is rated for 10,000 years. Only its polycarbonate outer layers reduce that to a mere 1,000 years."SSDs can lose data in as little as 7 days without powerhttps://www.extremetech.com/computing/205382-ssds-can-lose-data-in-as-little-as-7-days-without-powerTip: Keep your SSD cool.Data storage lifespans: How long will media really last?https://blog.storagecraft.com/data-storage-lifespan/Media Estimated LifespanMagnetic data (tapes) Up to 10 yearsNintendo cartridge 10-20 yearsFloppy disk 10-20 yearsCDs and DVDs 5-10 unrecorded, 2-5 recordedBlu-Ray Not certain, probably over 2-5 recordedM-Disc 1,000 years (theoretically)Hard disk 3-5 years - SSD is only 1-2 years unpluggedFlash storage 5-10 years or more (depends on write cycles)
Hey! Not a computer expert here but technically yes, but it is still very expensive. Anyway, another thing that I do is that my Sony A7II use SD card. So, in a pass few years when I went on a trip I will load up my A7II with a 16GB or 32GB card, usually Sandisk V30 type and use it through out the trip along with my film cameras and when I get home I load them up on to my Mac and back up HDDs. AND instead of reusing the SD card, I keep them on file along with my negative films I shot from the trip. SD card are not that expensive these days so why not! There's anther problem I see with digital storage is the future compatibility. I think that 20-25 years or even shorter from now there will be a problem reading those SD cards. Who knows 25 years from know there might be a new storage system and not backward compatibility. In theory digital photo files can live forever without any degradation. But I am actually worry more about loosing my digital photo files than photos taken on film. Well, as long as you can get a scanner in the future or just use macro lens with digital camera in the future I can still scan my films in the future. Take care,Buddy
I'm scratching my head at where they came up with this data. All my hundreds of CDs and tens of hard drives from the mid 90s up until today still work fine. At work we have thousands of hard drives, of which most are older than 3-5 years. I'd be more inclined to listen to companies that actually publish their raw data proving their stats than one just throwing stats out of thin air. Like this for example:https://www.backblaze.com/blog/2018-hard-drive-failure-rates/
