Neo 3/ Neo10 monitor thoughts.
0 Members and 1 Guest are viewing this topic. Read 17156 times.
HAL
Re: Neo 3/ Neo10 monitor thoughts.
« Reply #40 on: 31 Jan 2019, 03:47 pm »
Is Bohlender Graebener still in business? I did find info on the Neo 10 from Parts Express but Parts Express also stated  the Neo 10 is no longer available.
The BG data was purchased by Christie Digital and now makes them.
Just checked PE and it only says out of stock at the website.  I just bought some NEO10's and they arrived this week.
saygrr
« Reply #41 on: 31 Jan 2019, 04:35 pm »
Thanks for the info HAL.
Danny Richie
« Reply #42 on: 31 Jan 2019, 05:10 pm »
Actually Dia-ichi, a facility in the Philippines, made them for BG and Christy Digital.
Someone must of cleaned PE out on Neo 10's. I wonder who could have done that?
saygrr
« Reply #43 on: 31 Jan 2019, 06:53 pm »
I think someone by the name Danny did. With the new speakers you have you might be buying Neo 10s and Neo 3s as fast as they can make them. I know I'm interested in the Neo 10 / Neo 3 monitor with the 3 M-165 for the bass/midbass. I like the NX Ottica but I like this Neo 10/3 monitor more because of the size.
mkane
« Reply #44 on: 1 Feb 2019, 01:36 am »
now were on a roll
mkane
« Reply #45 on: 8 Feb 2019, 09:51 pm »
 First Lp still.
« Reply #46 on: 8 Feb 2019, 11:36 pm »
First impressions?
mkane
« Reply #47 on: 9 Feb 2019, 12:13 am »
 Excellent with the type of music we listen to. Acoustic & Classical most of the time. Fairly low volume. These could stand alone in the right environment. They can keep up with complicated arrangments. Imaging is excellent.
« Reply #48 on: 9 Feb 2019, 01:36 am »
Yes those neo drivers are insanely fast.  They absolutely love complex music.
HAL
« Reply #49 on: 9 Feb 2019, 02:01 am »
Sounds like my pair of Neo3/Neo10/servo sub speakers as well.
HAL
« Reply #50 on: 9 Feb 2019, 03:54 am »
Love my pair!
mkane
« Reply #51 on: 9 Feb 2019, 03:54 pm »
  Yours are finished. I was not going to use mine until they were sealed and painted. I caved. I should try out some diffusers. We listened to them for 5 hours yesterday. Very nice. Mabey a bit hot up top with our set up but that's easily rectified.
HAL
« Reply #52 on: 9 Feb 2019, 04:59 pm »
They were playing music long before the finish was done last year.
« Reply #53 on: 9 Feb 2019, 05:26 pm »
The speakers will mellow out in the top end quite a bit with about 200 hours of run in.
mdl62
« Reply #54 on: 10 Feb 2019, 01:19 am »
I have some N3S speakers that I have played for 100+ hours.
I hope there is some further taming of the upper range.
I also need to try different amps with them though.
I realize the N3S are different speakers but they do use the
Neo3 also
mkane
« Reply #55 on: 10 Feb 2019, 01:54 am »
  They will settle down with time. It easy for us to tame them while they break in being strictly analog. An SRA change, different cartridge loading, a VTF change to a different cartridge while these get some time on them. I would rather have em' with something up top than not. To reiterate, we really like this setup. Low-level detail is outstanding.
Danny Richie
« Reply #56 on: 10 Feb 2019, 02:34 pm »
Neo3 also
The response of those is really flat. So they may just be letting you really hear what your gear is added. In the end if you want to bring the level down then the top end can easily be adjusted with slight resistor changes.
mkane
« Reply #57 on: 18 Feb 2019, 02:06 am »
These monitors are the cat's meow with piano ensembles, violins, acoustic guitar. Most music where there's no sound coming from one's mouth. They have filled a void. thanks.
RichPark
« Reply #58 on: 23 Feb 2019, 05:39 am »
So the tinckley bits sound great.  What about the Vocals.
« Last Edit: 23 Feb 2019, 04:00 pm by RichPark »
mkane
« Reply #59 on: 24 Feb 2019, 03:56 pm »
 Usually switch to the Wedgies when it's vocal music day which isn't often.
