Will be interesting to hear your comparison results. It would be even more interesting to hear how it compares to a Tortuga (or similar) if anyone has one.Sumo
My friend Rex says it beats his Tortuga.
That will be interesting Charles. Probably one of the most unfair comparisons anyone can make.
True. Do not expect to be close but what the heck.charles
The preamp I replaced was the $1800 IFI Itube Pro Ican. Rex has both the Warp Speed and the Tortuga. I am thinking about trying the $59 3 input, 2 output. I could use more inputs. I have a couple of subs I could hook up to it also.
Can someone venture a guess as to how a $56.00 preamp displaces ones costing 30 times as much?? not 3 times as much .... 30 times!I understand that both labor and materials are cheaper in China… but 30 times less??
What do you call a "preamp"? Alps in a box is not a "preamp", it's just alps in a box. Before you fall over congratulating yourselves on bargain of the decade please get familiar with source impedance matching concepts.
It's just a potentiometer and a switch. Less circuitry can sometimes be better, it's very system-dependent. Balanced ones are not very common though, perhaps that's a reason for the good reports...Assuming I have the right one that is, it's cheaper on ebay https://www.ebay.com/itm/Fully-Balanced-Single-Ended-Passive-Preamp-Pre-Amplifier-XLR-RCA-Volume-Control-/272866696241
Yes, I've now realized there are several versions. Did someone post a link earlier? [Edit] Yes OzarkTom did. Sorry for the confusion
About the green ALPS 09: at low volume channels are often unbalanced, that is, the volume differs a bit. Only at the beginning of the turn. It is a common complaint.Off topic or not:I have an iFi iCan class A headphone amp and it has this small problem with the ALPS 09.
