0 Members and 1 Guest are viewing this topic. Read 103316 times.
lacro;Thanks for posting your pictures and links re: your input switch and DACT attenuator .I wondered if you preferred your DACT over the ALPS 27 pot ?Several people have posted positive experiences online with the DACT: and a couple of others have posted about returning to the ALPS after a period of use.I can't help but noticing that I don't see any mention of the use of the DACT in the build guides at diy audios Pass Lab. Just the ALPS .
Here is a Danish Dact for $350. I think still in the C&C range.https://www.ebay.com/itm/Passive-preamplifier-with-DACT-CT2-attenuator-and-CMC-golden-plated-RCA/202167840390?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
What the Chinese model offers that the others don't is two outputs, great for bi-amping, plus a third 'record' out that could be used to feed a subwoofer.
I thoroughly enjoyed this part of the description:"Box is made from exotic well sounding wood with wooden legs."You might not be wrong that this could be a quality unit for the cost, but I would probably recommend something like a Schiit Saga which has a remote for the same price. It's possible the stepped attenuators could be higher quality, but we don't really know.
Generally, "Record Out" are fixed level outputs that bypass the volume control, and would not be suitable to feed a subwoofer which would require variable line out.
Wouldn't a sub's own volume control and crossover work with the bypassed volume control from the dac?
