Always, always , get a second opinion. https://parttimeaudiophile.com/2012/12/30/mini-review-luminous-audio-axiom-ii-walker-mod/And another.https://positive-feedback.com/reviews/hardware-reviews/luminous-audio-technology-axiom-ii-passive-preamplifier/
You'll often hear people say that although they loved the transparency they missed the 'drive' or 'punch' of an active pre. Usually that's because of impedance mismatch, depending upon their gear. For those folks an autoformer or transformer based passive usually sounds better than just a switcher be it stepped or not. That's when the price starts going up.
It was Hugh's FAQ's that originally put me onto the Cermet pots (search the page for "cermet"). I meant to use this model pot from RS, but it was out of stock and then I got a slightly different version - with plastic shaft, but still Bourns.
OK plugged the sucker in. To my surprise out of box VG sound. If one uses an SET amp with low input sensitivity and a DAC with a 3V output or more this baby is for you. Big open sound. Transparent to source and DEAD quite. Compared to my Lamm bass MIA, harmonics lacking at extremes, less decay of harmonic and a bit hard and lean. The Lamm gives ya 1 thru 10 the passive 3 thru 8. For $56 a no brainer. charles
If everyone could hear a CD player direct into their amp, they would be shocked. I will never understand why people buy an expensive DAC with remote volume, and run it through a preamp.
I nominate Rollo as the most honest dealer in the world award. I doubt if you will ever find another that will compare a $20K plus preamp to a $56 passive and give an honest review like he did. I wondered how much it would cost to beat this passive. Now I know.If Charles sells any equipment you want to buy, buy it from him. You cannot go wrong.
I looked up the transformer based units. 30K for the Vivaldi? How does this one look to you?https://www.ebay.com/itm/AM-Audio-Music-passive-preamp-TVC-Type-transformers-Volume-control/192229314729?hash=item2cc1c290a9:g:A~UAAOSwyZ5UoGzF:rk:1:pf:0
Also try reversing phase at both speakers. This should give even a bigger soundstage. Anthony Gallo said years ago that most amps inverts phase.
