Terminating NES-3003
Pivotal74
Re: Terminating NES-3003
« Reply #20 on: 18 Jun 2025, 09:24 pm »
"We" do it this way because we found it sounds best.
BTW, where did you buy your cable?
I am now very upset. Someone else elsewhere has suggested conductor shield joined to it's respective "wrapper" that would logically give a hybrid conductor and leave the outer shield floating at both ends. HiFiCollective have no issue with your build  :?
For reference, I am bi-wiring both ends.
Now- I am curious about your build. It's not that I couldn't do it, it just appears awkward (I am 1/2 planning it in my head already). I am also curious to see your input on negative effect of shielding speaker cables when most of the net says you don't need to shield speaker cable at all. Any thoughts? My speakers are 96dB sensitivity and my monoblocks output 700W each.
Last question- I'm moving up from the Neotech Nemos 3080 and wondering if there is much of a performance increase in the 3003?
I am based in Ireland so the cable came from Audiohonics in France (discontinued) and HiFiCollective in the UK.
