**SOLD**Sumiko S5 Subwoofer by Sonus Faber aka REL T-5 (New Factory Sealed) $449
0 Members and 1 Guest are viewing this topic. Read 5460 times.
sean619
This subwoofer is white lacquer and brand new in a factory sealed box. I also have a piano black one that is mint, but I have used it for the last month. I only need to keep one of them for myself and I am happy to sell either color. I bought two, but I am so happy using one that I don't feel the need to have dual subs in my room.
Sumiko is a division of Sonus Faber and Sonus Faber helped design the Rel T-5. I previously owned the REL T-5, so I can tell you the main differences. The Sumiko uses a 150 watt amp and the REL T-5 uses a 125 watt amp. The Sumiko sub is a little heavier and the dimensions are a little larger. The Sumiko has an auto standby mode, the REL T-5 doesn't (only European versions do). When active, the Sumiko swirly logo glows dimly white and the REL T-5 logo doesn't glow. The sound of the two subs is very similar, but the Sumiko plays a little lower and adds a little more weight to the sound. Not sure if this matters to the sound, but the Sumiko sub does come with a much beefier power cord.
I will cover the Paypal fees.
Audiogon user: seanheis1
Will ship to US & Canada
Thanks for looking!
Price: $495 $449
Includes:
32.8 ft Neutrik Speakon© interconnection cable
Power Cable
Owner's Manual
Technical Specs:
Type: Closed Box, down-firing active woofer
Woofer: 1 x (8") very long throw
Amplifier: 150W rms, 250 peak
Active Drive Unit: 8 inch long-throw, steel chassis
Lower Frequency Response: 33 Hz at -6 dB
Input Connectors: Hi Level Neutrik Speakon, Lo Level single phono, LFE phono
Phase Switch: Yes, 0 or 180 degrees
Amplifier Type: Class AB
Dimensions (WxHxD): 11.2x13.2x12.4 inches (Including feet)
Finish: White Lacquer
Weight: 31 lbs – net weight
From the Manufacturer:
The Sumiko S.5 is the evolution of its smaller sibling, the S.0. While still compact, the S.5 gains some overall size to incorporate a larger driver, and provide more substantial bass reinforcement. This mid-sized woofer will be a welcome addition to any two-channel or multichannel system, providing a balance between accuracy and output.
The Sumiko S.5 utilizes a custom, 8-inch, long throw woofer in a cast steel basket, providing an additional 50% greater surface area over the S.0. A high current, 150 watt, Class AB amplifier to delivers thrill and excitement to your music, movie or gaming experience. Combine multiple S.5 units for more even bass distribution and greater impact.
About this unit:
Brand new-in-box Sumiko S.5 Subwoofer, in White Lacquer Finish. Subwoofer comes in factory sealed box, with mains lead, 10m/32.8 ft Neutrik Speakon© interconnection cable, and owner’s manual.
Similar brands: SVS HSU JL Audio Rythmik Sunfire REL
« Last Edit: 2 Jun 2019, 07:45 pm by sean619 »
sean619
bump
sean619
AvsFan
sean619
PM sent
AvsFan
Stereofro
Still Available?
sean619
Hi it is still available. Please message me your zip code so I can provide a shipping quote. Thank you. Sean
sean619
bump
sean619
bumps
sean619
bumpski
sean619
price drop to $449
sean619
sean619
sean619
sean619
sean619
sean619
sean619
sean619
