0 Members and 2 Guests are viewing this topic. Read 26347 times.
Is not buying a iPad the reason you don't just use the Bridge II in the DS Jr?
Ethernet in and Roon running on a NUC or Nucleus is all one needs IMO.
If you are still interested in a dsp you can try it still try it out with your macbook air. http://blog.roonlabs.com/digital-room-correction/Since your ps audio direct stream junior is Roon ready, just install the Roon server on your macbook air with a trial or short subscription and give it a go with the roon app. Also have you tried a uPnP mediaserver like MinimServer running on your mac with the ps audio app? If that works for you then maybe a small synology or qnap nas server running a pnp media server. Did i read this right that the direct stream jr converts all pcm to dsd?
Roon just isn't worth $500 IMO for metadata/Tidal integration and therefore neither is Roon Nucleus. Would Roon Nucleus sound any better than the SGC/Roon?It's been 35 years since I DIY'd (those were 'simple' kits) and I'm a certified computer dummy.
It seems disingenuous to continually reject Roon as costing $500 when, in fact, it costs $120/year ($10/month) or $500 for your entire lifetime. Not finding value is a personal decision. Misrepresenting the terms Roon requires to provide their services is a disservice to them.I notice too that you are confessing your inability to make computer decisions yet reject any and all suggestions (in advance) that might address a computer inadequacy as your limiting factor. If you really want a solution, and your frustration is as represented, you might benefit from opening your mind to any and all possibilities. TomS seems to feel he has nearly identical equipment and is telling you how he made it work. Why not just follow his advice? He makes it sound easy. Were you unable to imitate his solution in your system?
... which he summarized as Tidal Integration and metadata. We both know Roon offers much more than those two. [snip]
For me Roon only added Tidal integration and metadata, nice but not worth $500 IMO.
What is "uPnP mediaserver like MinimServer" and "synology or qnap nas server running a pnp media server"?
Yes, as I've read DSJ converts all incoming formats to DSD256 to make computing simpler, why do you ask?
I chose to use an iPhone SE (small format, like the old 4S) so too small of a screen for music apps. Prefer using the MacBook Air on my lap with a real keyboard versus holding/using a tablet plus already own the MacBook. This is non-negotiable. I'm a "bit" of a luddite compared to most of you and don't want to fill my life (and Apple's pockets) with Apple gizmos. As I stated before my MacBook Air with iTunes via a 10ft USB cable sounded just as good as the SGC/Roon via ethernet.
Half of you say servers can make a sonic improvement, half don't. Life would be simpler/cheaper just staying with what I've got. Will keep looking but I can wait for this whole business to get undisputedly better (sound quality wise) and the user friendier to setup/use (like a microwave oven).
I feel Roon does a horrible job with Tidal integration and that's why i'm not a subscriber, but the metadata is nice and agree it's not worth the cost for my needs.
That's the most bizarre things I've seen in this thread. It's ONE of the BEST things it does. The integration is truly seem-less and amazing. What does it not do for you?
I did try to connect the DSJ to the network via ethernet/HomePage but it wouldn't play iTunes or Tidal, unlike TomS who was able to do with Spotify and possibly some "computer magic" that I'm unable to perform.
Would you be open to a device that you can select as a speaker in iTunes?
So you're telling me you went to Tidal via USB and selected the output below and it doesn't play?
