Sanders Magtech amplifier / 500W @8 ohms, 900W @4 ohms
0 Members and 1 Guest are viewing this topic. Read 869 times.
pdj
Highly regarded Sanders Magtech amplifier in excellent condition.
Please Google "sanders magtech review" for reviews and descriptions of its unique technology.
Great for driving electrostatic, planar ribbon or magnetic speakers. Don't let its compact size fool you...this thing has punch yet is very musical.
Shipping within continental US included.
Buyer pays 3.5% Paypal.
The Absolute Sound Editor's Choice Award winner.
"This no nonsense amplifier was designed to drive any loudspeaker impedance, particularly full-range electrostatics, which can have an impedance of less than an ohm in the top octave. The Magtech “sounds as if it had infinite power into anything with total stability,” said REG. The fully regulated power supply is unusual. The rated power output of 500W into 8 ohms and 900W into 4, coupled with its stability driving capacitive loads, makes it the perfect choice for electrostatics."
SPECIFICATIONS 500 watts RMS per channel into an 8 ohm load 900 watts RMS per channel into a 4ohm load Bandwidth DC through 100kHz Class of Operation Class AB Slew Rate 500 Volts/microsecond Input voltage required for full output 2 Volts Input Impedance 50Kohm (both balanced and unbalanced) Gain 26dB Noise More than 110dB below rated output Damping Factor Greater than 600 into an 8 ohm load THD Less than 0.004%, 20 Hz - 20 KHz IMD Less than 0.003%, 20 Hz - 20 KHz Voltage Voltage is user selectable for use world-wide. Dimensions 17" wide x 5.5" tall x 16" deep Weight 55 pounds Includes: power cable, manual, original box.
$2999
« Last Edit: 29 Nov 2018, 08:44 pm by pdj »
