0 Members and 2 Guests are viewing this topic. Read 18144 times.
According to your linked website, the Aretha model uses 6sl7 tubes, not 6sn7.As per the same website, the Ella model uses 6sn7.
Did you check with the builder? I only ask because I'd like to consider possibly buying this preamp, and I'm curious about all its options and features.
Take a look here:http://www.erhard-audio.com/ Formerly know as Tube Nirvana.I had Holger build an "Aretha" preamp. Uses 6SN7 tubes. Excellent build quality.It has been trouble free for the three years I have had it. It now is available with remote.I have used this with my MKIII mono blocks as well as my Stratos Extreme. Sound is Excellent.Welcome to give it a listen if you are in the area.Hello Bob,I'm considering the Aretha because of the tone controls. What is your opinion of their functionality?TIA,LesWell within the price range. I would rate this as comparable to the Sachs unit.
I have an SFL-2 and it's very nice.Lots of detail but if you want tube warmth it's not the one for you.
