stratos and khartago amp capacitor
0 Members and 1 Guest are viewing this topic. Read 5395 times.
cheehpogi
« on: 27 Oct 2018, 06:05 am »
Does the two amp have the same value of capacitor? I was checking both amp and cannot see any writing. Does anyone care to share  their values, uF and voltage? for the power cap and electrolytic cap.Thanks.
klaus@odyssey
Re: stratos and khartago amp capacitor
« Reply #1 on: 30 Oct 2018, 12:22 am »
There are essentially 4 different ps caps that we use....our regular 15,000 uF caps made in Taiwan (NOT CHINA  !!!!  They also have a Shenzhen factory, but I'm paying a cool 40 % more by have them done in Taiwan instead) according to our specs,  and then there are the much, much more Symphonic Line designed caps made in Germany,  15 K snap ins,  tall 16 K screw-ins,  and the 35,000 uF  hyper cap beer cans....the 15 & 16k caps can be substituted in every model,  but the big mommas should only be used with the 800 + VA  transformers to keep PS and performance balanced....
steverii
« Reply #2 on: 30 Oct 2018, 01:04 am »
Hey Klaus, I have Kismet monos in Stratos cases. They use a single 650VA transformer in each case. They also have SL caps, but they are not 35,000 mF. Can I upgrade to the larger transformers and larger caps? And if so, how much would it cost? Amps are powering Maggie 2.7QR's so I can use all the power I can get.
Thanks, Steve
cheehpogi
« Reply #3 on: 30 Oct 2018, 04:48 am »
Thanks Klaus, appreciate it very much. what about the voltage for the 15k what do you use?
klaus@odyssey
« Reply #4 on: 30 Oct 2018, 04:51 am »
63 Volts...amps have a rail voltage of appr. 55 V....and Steve,  yes....call me ......
cheehpogi
« Reply #5 on: 31 Oct 2018, 02:42 pm »
Thanks again Klaus.
klaus@odyssey
« Reply #6 on: 31 Oct 2018, 08:26 pm »
Hyper caps are 80 V
