Super Alnico High Output XRS Amp Synergy
0 Members and 2 Guests are viewing this topic. Read 20370 times.
opnly bafld
Re: Super Alnico High Output XRS Amp Synergy
« Reply #20 on: 21 Oct 2018, 09:08 pm »
A and B speakers outputs; 16, 8, 4, ohm outputs; speaker biwire outputs.
scottschecter
  • Call me Deacon Blues
    • LinkedIn
« Reply #21 on: 21 Oct 2018, 10:00 pm »
The Franks had nominal Impedance from 3 -16 ohms on both posts. A/B and biwire use cases make sense. Thanks for that.
sunnydaze
« Reply #22 on: 21 Oct 2018, 10:40 pm »
For my own edification, why do manufacturers include multiple speaker level outs then?
To present different amp output impedances to the speakers.  4 and 8 ohm posts on the amp are most common.
Or, if both posts are the same output impedance, to make it easier to bi-wire.   Sometimes, 2 spades are hard to attach to the same post.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« Reply #23 on: 22 Oct 2018, 12:02 am »
Seems like you could just run cable to your main speakers and the the subs from there.  My subs are close to the mains.  Some don't do it that way.  I use the subs' low level inputs from the preamp anyway.  So I guess I'm "just sayin'".  :wink:
         ......Peter
sunnydaze
« Reply #24 on: 22 Oct 2018, 12:22 am »
         ......Peter
I sometimes do it that way too......
spkr cables from main amp to main speakers;  then cables from main speakers to sub
scottschecter
    • LinkedIn
« Reply #25 on: 25 Oct 2018, 02:45 am »
Spoke with Louis today and ordered the Super Alnico High Output XRS in Real Walnut :thumb:. Louis was super helpful and a pleasure to chat with.
Doodlebum
« Reply #26 on: 25 Oct 2018, 11:58 am »
Wow, I would love to have those. Great choice! I just got the super8XRS jrs. I'm very happy with them, no harshness at all, super detail and fantastic bass. I can only guess how good the ones you ordered will sound.
jmolsberg
« Reply #27 on: 25 Oct 2018, 03:41 pm »
nice choice..  which SET did you decide on? i use a decware zen/zrock2 with my 3xrs HO, but lately i've been running it with 1 watt LTA MZ2/zrock2, and man it is impressive.
scottschecter
    • LinkedIn
« Reply #28 on: 25 Oct 2018, 04:26 pm »
Based upon the sage wisdom of MarkR7 I went with the Coincident Frankenstein M300b mkII mono blocks. Can't wait to hear how everything sounds together once it all arrives. :thumb:
jmolsberg
« Reply #29 on: 25 Oct 2018, 06:33 pm »
Here comes an exercise in patience
scottschecter
    • LinkedIn
« Reply #30 on: 25 Oct 2018, 06:35 pm »
So true!
Camus
« Reply #31 on: 10 Feb 2025, 12:04 am »
On these speakers it lists the impedance as 4-6 ohms, my 300B amp only has an 8 ohm speaker tap. I have read and been under the impression that when the speaker present a lower impedance it requires the amp to work harder, how much of a mismatch would this end up being despite the  97dB sensitivity?
Thank you for helping me better understand the impact of the less than 8 ohm load!
opnly bafld
« Reply #32 on: 10 Feb 2025, 02:03 am »
I don't think the impedance itself is a problem, but how the bass may sound with your amplifier. What is your amp?
Suggest calling/emailing Louis.
Camus
« Reply #33 on: 10 Feb 2025, 02:23 am »
Thank you for the input and suggestion!
It is a custom built 300B using C3G as input tubes and a GZ34 rectifier. The output transformers are Hashimoto, all the transformers and chokes are Hashimoto. It has 32 ohms tap for headphone output, then the 8 ohm speaker taps on the transformers.
opnly bafld
« Reply #34 on: 10 Feb 2025, 01:33 pm »
Sounds like a very nice amplifier.
Hashimoto OPTs usually have multiple output taps, if yours does you can move it to 4 ohms.
seikosha
« Reply #35 on: 10 Feb 2025, 02:30 pm »
Your amplifier will be fine, I suppose it’s possible that it won’t be able to quite put out its full output, but you’ll still have plenty of power for that speaker if your listening levels are reasonable.
Camus
« Reply #36 on: 10 Feb 2025, 08:25 pm »
It’s been great with headphones, unfortunately I haven’t had a set of speakers sensitive enough to match up to it  :cry:
The manner the amp is built I have no direct access to the portion of the transformer with the various taps available, which from the spec sheet it does not have a 6 ohm tap….
Thank you for the insight on power output, I live in a condo so no blasting out AC/DC or such at high volume!
Any reason these particular speakers list 4-6 ohms? I know speaker loads can sometimes dip below their stated rating, never came across a spec with a range before.
Upon more thinking, the obvious solution is the Junior XRS as those are listed as 8 ohms, however I don’t want to have any misgivings if I can find a way to use the SAHO XRS with my amp.
opnly bafld
« Reply #37 on: 10 Feb 2025, 09:15 pm »
2 drivers in parallel.
