Next SoCal Listening Session
0 Members and 1 Guest are viewing this topic. Read 6775 times.
John Casler
« Reply #20 on: 7 Feb 2005, 03:51 pm »
Quote from: rlcordeiro
 John,
I am now very unhappy with my system now after listening to yours. I guess I will need help fixing mine soon.
Ranjit,
That is easily fixed.  Since you have better gear than I do, it is probably just a matter of "tweaking" a bit with the room and placement.
The other issue (which we already discussed) is stepping up the CD/DVDplayer, and maybe the LARGER Subs.
You have a good ear and your assessment of the relative Bass Loudness at higher volumes was correct.
I normally don't listen at the levels we were using, so I have the bass adjusted "slightly higher" to compensate for the lower volume (Fletcher-Munson).
Without being in the sweet spot Sat, I didn't make any assessments, since bass response closer to room boundaries (where I was standing) is generally going to be stronger anyhow.
Jon L
« Reply #21 on: 7 Feb 2005, 05:52 pm »
"I normally don't listen at the levels we were using"
Now I'm not sure I should really believe that  :D
There's actually quite a bit of new and exciting gear to listen to among our new "acquisitions."  We just need to come up with a good (long) day..
KeithR
Back to tubes...
« Reply #22 on: 20 Feb 2005, 03:03 am »
Ah yes, the big BAT finally arrived and is breaking in perfectly.
I think you guys are in for a treat :)
I suggest Saturday Feb. 26th at noon if possible, so we have a few hours.
I can hold many folks comfortably, so no issues with space!
Please PM me if you are coming and I can return with address/phone etc.
Keith
jswallac
« Reply #23 on: 20 Feb 2005, 03:09 am »
Can't make the 26th, but if it ends up being on Sunday instead I would like to come.
John Casler
« Reply #24 on: 20 Feb 2005, 05:13 am »
Glad to hear the BAT is on the scene.
Either Sat or Sun works for me, no problem
John Casler
« Reply #25 on: 24 Feb 2005, 09:36 pm »
Keith,
Are you still doing the BAT/Wilson show this weekend?
