0 Members and 1 Guest are viewing this topic. Read 31552 times.
I don't believe NHT offers the preamp version with their control box, but I'm wondering if you can verify that. Not a huge deal if not, but it does need to be factored when comparing costs to the DEQX system. Also, do you know if this has enough gain to use a passive preamp?
As I mentioned in another thread, DEQX will be releasing two new versions of their PDC, which will include 4-channel digital amplification. One of the two versions will also include a preamplifier. They demo'd them at the CES.
Quote from: Rob BabcockDEQX can't change the laws of physics.No, but it gives you a complete tool kit for dealing with physics that really hasn't existed before. Still, the driver/cabinet design is even more critical than ever because now that is more the limiting factor than ever.
Good answer, even if it is pure sophistry. I was talking only about dynamics, which should have been obvious. The steep X-over may improve power handling to a good degree, but what in it's radical new toolkit will make it play as loud as, say, a pair of RM-40's or GR Alpha's?I'm sure it sounds nice, though.
OBF,I've heard from a speaker maker that they(DEQX) will sell him OEM DEQX's that he can (must) lock in the speaker XO parameters and just have the room correction for the end user to adjust. He can get that at a pretty good discount, he mentioned, but he never elaborated what the disount was.
Would the owner be able to defeat those settings or know what they are from the software / hardware interface?Rick
Who the heck is Joel Bernstien?
Quote from: John AshmanWho the heck is Joel Bernstien?I'm sorry I misspelled your new name on AVS. It should have been Joel Bernstein.
From the DEQX website:Pre-Corrected Loudspeakers (OEM Modules)Loudspeaker manufacturers can implement DEQX Calibrated™certification into existing designs using DEQX's OEM DSP / digital amplifier modules which can be customized to specific physical and I/O requirements. Since the unique pseudo-anechoic measurements are made at time of production, there are no set up requirements for the user. Register your interest in DEQX OEM modules.You probably only need to order 500 at a time.
From the DEQX website: Pre-Corrected Loudspeakers (OEM Modules) Loudspeaker manufacturers can implement DEQX Calibrated™certification into existing designs using DEQX's OEM DSP / digital amplifier modules which can be customized to specific physical and I/O requirements. Since the unique pseudo-anechoic measurements are made at time of production, there are no set up requirements for the user. Register your interest in DEQX OEM modules. You probably only need to order 500 at a time. Quote from: Rick CraigThanks Mike but you still didn't answer the question. Ever think about politics as a vocation ?
