0 Members and 1 Guest are viewing this topic. Read 3874 times.
I'm unfamiliar with that tube designation, but if you can verify it's an electrically equivalent tube then you should be fine. Different countries often designate tubes with different designations. Without looking into it, I would bet the 6u5c is a Soviet tube.
Thanks Gopher, my bad, I meant 6X5. I understand the EZ35 is functionally equivalent, which is what I purchased. The issue is the pins on the EZ35s I have are not the same as the factory fitted 6U5C. Is an issue?Thanks
