0 Members and 1 Guest are viewing this topic. Read 13539 times.
When I made mine I used the resister, I have no idea if it makes a difference. I do know that if you are trying to protect against RFI/EMI you need to buy shorting plugs not just plastic plugs. How many are you looking for? I may have some around here but would have to look.Greg
I have three outputs on my preamp. One is unattenuated and throws out full volume which i think is used for a tape out. I've been thinking of putting a plug on it, so I don't make the mistake of using it as an output as I have done on occasion. They are unmarked and I forget which is which and I'm feeling around the back blind w the pre in the cabinet. I assume they do no harm?? Any cheap ones out there?
I've been thinking of putting a plug on it, so I don't make the mistake of using it as an output as I have done on occasion. ..... Any cheap ones out there?
it depends on which ones you get, some just keep the dust out while others (shorting plugs) stop interference from coming in thru the unused ports.here are the ones I use. they also make one for digital inputs.https://highend-electronics.com/products/highend-electronics-analog-terminator-shorties
So now my question is - because I'm on a budget. Can I buy these?
