Absorbers under Costco canvas?
0 Members and 1 Guest are viewing this topic. Read 5365 times.
Photon46
Re: Absorbers under Costco canvas?
« Reply #20 on: 23 Aug 2018, 11:13 pm »
If you order from an art supply dealer, you can get much heavier duty stretchers the the thin ones you find in your average arts & craft store.
https://www.dickblick.com/categories/stretcherstrips/
artur9
« Reply #21 on: 24 Aug 2018, 12:56 pm »
I actually got mine from a B&M Blicks!
MarvinTheMartian
« Reply #22 on: 24 Aug 2018, 03:26 pm »
www.primacoustic.com/broadway-panels/
Have an interesting twist on the standard wood frame construction.
They reinforce the OC703 edges by applying a thick coat of glue.
Thinking 3 perimeter coats of epoxy applied with a roller. Soak the corners?
I'm a woodworker first so I have never tried this technique.
Also like their idea of cheese cloth? / 3M 77 spray adhesive containment cover.
Shawn
