0 Members and 1 Guest are viewing this topic. Read 14492 times.
Thank you for the reply....ordering a C100s this week.One other question......If connected directly from a CPU sound-card (balanced in/out) is it better to put an attenuation before the amp...like your passive options or an active pre ?.... just in case the PC app does not attenuate ? I have options here.BTW, is K. Halverson associated with you guys ? In storage, I have a Muse 175 monoblock pair. Might want a re-cap ?
Ordered the 100s amp, and the PLC 1 mkII (passive w/remote) Done deal.Thanks so much.I have previously built cables to match my soundcard's balanced output, to single-ended. (Pin 3 disconnected at the destination.) (RME soundcard)If I finally get my VPI scout turntable out of storage, I might check out your Phono Pre.
