SOLD - FS: Peachtreee Audio deepblue2 Bluetooth Music System $225 ea. SOLD
0 Members and 1 Guest are viewing this topic. Read 585 times.
Freejazz
Sold - Thanks to all.
Selling two (2) units of the second version Deepblue Bluetooth integrated music systems - the deepblue2
All units are original with no mods and include original box, operating manual and power cord.
Each unit is in VG+ condition. Having upload issues, so I will be happy to provide individual photos for anyone interested
I have used both units lightly in a library and bedroom system. They provide quite nice sound and are modest in size, yet high in enjoyment. As with most Bluetooth speakers, they can be a tiny bit finicky on the rarest of  occasions with pairing/connecting, but are otherwise pretty much bulletproof.
I have compared them to the Google Max and Apple Home. They beat the Max and are more musical and less boomy than the Home. A different flavor for us each.
Selling only due to A move to the dreaded 55+ Community and resultant downsize.
Asking $225 each or $400 for both.
Shipping is at actual cost to purchaser’s location.
Please add 2% for payment by PayPal in US and 4% Worldwide.
Here is the manufacturer’s original product description:
The Ultimate Bluetooth Speaker
deepblue2 redefines the quality and quantity of sound possible from a Bluetooth speaker. It combines the convenience of a single box design with the full-range powerful sound of a big HiFi stereo system. With deepblue2 you'll experience irresistible sound that you can easily move from room to room.
Raising the Performance Bar
In 2013 Peachtree Audio launched the original deepblue. It received rave reviews from the media and customers alike and quickly established itself as the answer to the question "What's the best sounding Bluetooth speaker I can buy today?"
With deepblue2 our design team has committed to raise the performance bar even higher than the original. The technical challenge is to get controlled, deep and loud bass extension out of a small cabinet - and to do that without a wallet devastating price tag.
Most wireless speakers use two or three small speaker drivers operating at their maximum potential to try to achieve full range sound. The result is thin and compressed sound that is fatiguing to listen to at high volumes. They simply run out of gas.
For truly life-like sound you need a speaker capable of producing deep bass and the only way to do that is to move lots of air. You need to have the right combination of power, surface area, driver excursion and correct enclosure all working together. We're not breaking the laws of physics. We're exploiting them to make the biggest sounding Bluetooth speaker ever made!
deepblue2 uses a custom developed 440-watt amplifier that is 5X more powerful than the home Bluetooth speakers currently on the market.
A massive long excursion 6.5-inch woofer moves a serious amount of air and creates deep impactful bass. You not only hear full bass, you feel it.
deepblue2 uses a total of five speakers in a three-way configuration to create a powerful balanced sound so every instrument and voice can be easily heard. Two 3" mid-range drivers and two 1" soft-dome tweeters flank deepblue2's woofer to create a wide natural sound that fills an entire room.
A very carefully designed acoustic suspension enclosure separates deepblue2 from everything else on the market. Our sealed box approach outperforms the typical ported box and passive radiator designs by creating clean deep bass that doesn't distort at high volume.
aptX® Bluetooth audio streaming
Stream all of your favorite music and apps to deepblue2 using its built-in aptX® Bluetooth audio receiver. You can pair your Android, iPhone, iPod touch, Macbook and most PCs for high quality wireless audio streaming.
With Bluetooth you don’t need any proprietary apps. Use the ones you already love and are familiar with: iTunes, Windows Media, Pandora, Spotify, LastFM, and more, are easily streamed wirelessly.
Connect up to five Bluetooth devices and toggle through them by simply pressing the BT button. This is a great feature if you use multiple devices. They stay paired - you just keep them in range and switch between them as desired. Switching between your PC and mobile phone, for example, is now super easy!
Digital and Analog Inputs
deepblue2 features two wired inputs: one optical and one 3.5mm analog. Want to connect an Apple TV or Amazon Fire TV? No problem. Sonos Connect? Ditto. Dig vinyl? You can do that too by using a turntable with a built-in or external phono preamp.
deepblue2's optical digital input accepts high-resolution 24/96 digital audio for better-than-CD-quality sound. If your HDTV has an optical digital output (most do) you can even use deepblue2 to listen to TV, movies and games! Awesome.
Play In Any Room At Any Volume
Play It Low or Play It Loud
The human ear is less sensitive to bass frequencies at low volume. deepblue2's Smart Volume automatically adjusts frequency response at the low end of the volume range to compensate for the ear's lower sensitivity. This means you get full and clear sound even at very low levels.
For those times you need to let loose and turn up the sound to party level, Smart Volume will lower peak signals to ensure great distortion-free sound and the long lasting performance of your deepblue2.
Perfect Sound In Any Room
deepblue2 is voiced out of the box to produce the most balanced bass response in the places where it'll be most commonly placed. However, it's impossible to predict every situation where a speaker is going to be located. You may also prefer more or less bass. Using the included IR remote control you'll be able to toggle between five different bass levels to fine tunedeepblue2 to your environment and personal taste.
Easy To Move
An easy-to-grab recessed handle on the back panel makes it easy to move deepblue2 throughout your home.
Specifications
Acoustic Design:
1 x 6.5-inch low frequency driver
2 x 3-inch midrange frequency drivers
2 x 1-inch high frequency drivers
Acoustically sealed cabinet
Power Amplifier: 440 watts
Inputs:
aptX® Bluetooth wireless with up to 5 connected devices
Optical Digital Audio (Toslink)
Line-level Analog Audio (3.5mm)
Dimensions (H x W x D):
9.1 x 14.2 x 6.5 (inches)
230 x 360x 164 (mm)
Weight:
16 pounds
7.3 kg
AC Input: 100-240V 50/60Hz
« Last Edit: 20 Sep 2018, 12:27 am by Freejazz »
