Re: Ref 3a Royal Virtuoso...
0 Members and 1 Guest are viewing this topic. Read 5703 times.
flm
« on: 13 Jan 2005, 01:30 am »
Hi,
I am considering the current Royal Virtousos and was wondering if anyone knows if the crossover capacitor is different from the de Cappo i? Also, is the tweeter for the Virtuoso different from deCappo i or the same model but matched to better tolerances? Lastly, does the Virtuosos use Cardas internal wiring instead of vandenhaul?
melville
E-mail Reference 3a
« Reply #1 on: 14 Jan 2005, 05:45 pm »
I own the Royal Virtuoso speakers, and love them; however, they really do need to be used with a good tube amp.  Mine work very well with my Art Audio Carissa.  You should really e-mail the 3a website to get the information you ask for.
flm
Re: E-mail Reference 3a
« Reply #2 on: 14 Jan 2005, 06:34 pm »
Quote from: melville
Hi Melville,
Thanks I will contact ref 3a!
I was wondering though, does your tweeter have 4 inner screw holes with no scews in them as pictured on the website (same with de Cappo i). I see that only the 4 outer set being fastened by screws. But if you look at the L'integral Nouveau there are 8 screws fastenng all the holes of the tweeter plate.
melville
Screws
« Reply #3 on: 14 Jan 2005, 11:55 pm »
My tweeter surround has four outer screws, and four slightly smaller inner screws (all heads showing).
Brian
flm
Re: Screws
« Reply #4 on: 15 Jan 2005, 01:34 am »
Brian
Hi Brian,
Thanks for the info and if I can bother you with one more question. What type of screws are used to fasten the tweeter & woofer? i.e. phillips, flat head or hex nuts.
Regards, Frank
melville
Screws
« Reply #5 on: 15 Jan 2005, 06:58 pm »
I am embarrassed to say that, even at my relatively advanced age, I have not sorted out Phillips from Robertson.  So, I will describe them as square- pattern for inner, and cross-pattern for outer, screws.  All screws are flush with the surrounds.  The mid/woofer surrounds are attached with 8 round-headed 'cross-pattern' screws.
flm
Re: Screws
« Reply #6 on: 15 Jan 2005, 07:10 pm »
Hi Brian,
Thanks again for all your help!
Regards, Frank
