0 Members and 1 Guest are viewing this topic. Read 7021 times.
When more than one woofer share a vented enclosure they should not be identical--the result is tubby, one-note bass.
On the RM 30, the two 6.5" actives are the same.
The two 6.5" passives are slightly different from one another.
However on the 30's the midbass drivers are already physically different...
The only reason to change the midbass woofer in the 40's was because it was the same size as the low bass woofer (both are 10 inches). Since the midbass woofers in the RM30's are already different than the low bass woofer, I doubt there is any need/reason to make any changes to the 6.5 inch midwoofers at all.
Clear as mud?
1) This "magnetism" solution only applies to identically sized drivers inhabiting a single airspace when the different drivers cover different parts of the frequency spectrum. (i.e. the RM30 uses all 6.5" drivers solely for mid-bass, and not a split between mid-bass and low-bass like the RM40's)
Brian and/or John,How are the midbass upgrade program going? Are you close to shipping them?
QuoteHowever on the 30's the midbass drivers are already physically different...Are they really? I guess I missed that tidbit. I thought they were both identical 6.5" WCF cones? Guess I'll wait for Brian to chime in.-KJ
The 6.5" drivers are physically different than the 10" driver they share the same space with, not each other.
