Dac2 left channel not working
guf
« on: 23 Jun 2018, 06:43 pm »
After hours of thinking my left channel was not working because of my amp or tubes I realized it was the Dac2. Is there anything I can do? I think it's 2 years old.
guf
Re: Dac2 left channel not working
« Reply #1 on: 24 Jun 2018, 09:02 pm »
I banged it a few time on the side and now its working. go figure.
timind
  • permanent vacation
« Reply #2 on: 25 Jun 2018, 12:07 am »
I recently had no sound from my amps left channel. After plug to see if it makes contact. a lot of swapping every which way I discovered the RCA jack on the amp was not making contact with the RCA plug. I expanded the RCA plug tip and it worked. The problem though, is the jack (female) is too big. Gonna replace the jack.
Suggest you wiggle the RCA
