ACI TITAN II LE
0 Members and 1 Guest are viewing this topic. Read 2978 times.
Ssingh
ACI TITAN II LE
« on: 23 Jun 2018, 01:27 am »
Calling Mike Dzurko (or anyone else who has done this) - amplifier on above sub has died, can anyone suggest a replacement?
hdspeakerman
Re: ACI TITAN II LE
« Reply #1 on: 23 Jun 2018, 02:05 am »
Parts Express has a big selection of  plate amps for subs.
fredgarvin
Re: ACI TITAN II LE
« Reply #2 on: 23 Jun 2018, 02:12 am »
The Bash amps are pretty good for that application.
jparkhur
Re: ACI TITAN II LE
« Reply #3 on: 23 Jun 2018, 12:04 pm »
They were made by Triad.  You could see if it is worth sending to them or find really any plate amp with similar drop in dimensions.  I have done the same and worked fine.
Ssingh
Re: ACI TITAN II LE
« Reply #4 on: 25 Jun 2018, 12:16 am »
Thanks guys! Found someone locally who is willing to take a shot at repairing the amp; seems most likely the capacitors are shot. If that fails then will look at getting a drop in replacement. Unfortunately I'm on the other side of the world so if parts+shipping turns out to be too much I guess its time for a new amp.
