Where are we on the balance control update
glynnw
  • I have tin ears.
« on: 20 Jun 2018, 05:55 pm »
You have probably covered this, but I am old with a bad memory (any excuse I can use).  What is the status of the balance control that maintains overall volume level when using the balance feature.  That is the feature that will cause me to update.  Thanks.
tortugaranger
    • Tortuga Audio
Re: Where are we on the balance control update
« Reply #1 on: 20 Jun 2018, 06:19 pm »
Overall volume is maintained during balance adjustment. This feature has been incorporated into the V25 preamp controller firmware from the beginning and continues as part of the OLED display upgrade.
