0 Members and 1 Guest are viewing this topic. Read 6473 times.
Have a peak here: http://daudio.nl/ontwerp/It's in Dutch (Google translate is your friend), but if you email them they will answer your questions.
Mundorf AMT25D1.1. I don't see it as being particularly "copycat"... but do wonder why this discussion is not about nearfield OB subs
So order of operations:1: Pull couch out from wall. Stick el-cheapo sub box (sealed) back there. Perform sweeps.2: Chop back of el-cheap-o box off to make also-el-cheap-o U-Shaped OB. Perform sweeps. Move things around. Hopefully learn.3: Build test box with some capability of adjusting slot width. Test for impedance peaks, compare to freq response at listening positions. I foresee this taking me a while.4: Based on all the above and some leaps of faith, start the real build. I'll take pics along the way. Chris
Seems these OB are not good bottom dwellers
System is impractical for infrasonic reproduction
