Remote control for the Isabella
gooner
« on: 15 Jun 2018, 10:35 pm »
Dear Sirs,
I need a new remote comtrol as the buttons on the plasticly one I have is about to disintegrate :duh:.
Will a remote from another brand do the same job or do I need to buy a new one from RWA, at what price?
Gooner of Norway. :)
« Last Edit: 16 Jun 2018, 09:58 am by gooner »
Vinnie R.
    • http://www.vinnierossi.com
Re: Remote control for the Isabella
« Reply #1 on: 16 Jun 2018, 01:39 am »
Hi Gooner,
You can purchase replacement remotes for Red Wine Audio products from Bent Audio:
http://bentaudio.com/index2.html
On the left hand column, click on "Remote Handsets."
The two-button metal remote will work fine.
Best regards,
Vinnie
gooner
« Reply #2 on: 16 Jun 2018, 09:59 am »
Excelent, sir, thanks a bunch! :D
cinjun
« Reply #3 on: 13 Jul 2018, 03:35 am »
Will that remote work with a Signature 15?
Vinnie R.
« Reply #4 on: 13 Jul 2018, 02:50 pm »
Hi cinjun,
Yes, and it will work for all Red Wine Audio products.  :thumb:
Vinnie
