Fuse Size for Big 7
0 Members and 1 Guest are viewing this topic. Read 2412 times.
Labpro
Fuse Size for Big 7
« on: 5 Jun 2018, 12:37 am »
Recently took delivery of a Big 7. Can someone tell me the size fuse I should be using.
I believe 2A slo blo "20mm" is what I need, however I read somewhere that "25mm" is used.
Technically you can use up to a 3.15A......is there a "fidelity" difference between a 2A and a 3.15A?
Thanks for the assist.
Labpro
