0 Members and 1 Guest are viewing this topic. Read 3869 times.
You've also confirmed that the settings in Foobar and JR on the new machine match those of the old machine? Are the driver versions on both machines identical?
… If it is a new computer, return it as not usable. You have a right to return crap that fails to work properly..
Yep; that's what ya' do.
Oh man, it's dirt cheap, well built, compact and light - just what I wanted. I wanted a portable internet laptop but also just to play my music via JRiver. *sigh* Bummer.
You might contact the manufacturers Support site and see if they can help.
Maybe the latency is too high to maintain a steady stream.Try any DPC latency checker to make sure: http://www.thewelltemperedcomputer.com/SW/AudioTools/TroubleShooting.htmA shot in the dark, if you have a USB hub, connect the DAC to the hub
