0 Members and 1 Guest are viewing this topic. Read 13830 times.
Not fond of B-II though.
Can you elaborate? What do you not like about Bridge 2? I am not a fanboy defending the product. I do not yet own DS, but I am considering upgrading from my Vega. Constructive criticism is hard to find on this model. Thanks!Rich
In my setup I find the USB to sound better but you would need a good quality server/streamer (likes of Sotm, etc). I have even removed the card from DS which further improves a bit of SQ. If you want to go the B-II route, make sure you have a good foundation with the Ethernet switches and cables and a good LPS to power it up.
In my experience, I have found absolutely no sonic difference between the sMS-200, Allo USBridge or PSA Bridge II. This was all done on the fly and switching the input during playback via Roon with all zones in sync.
On a different note, there is B-III in the making
Which might not support Roon...
Thanks debjit! I have SMS-200 with Curious USB pigtail cable, it's a great combination. But I'm still using stock PS for SMS200.
fwiw, I have read (forget where) that an audible improvement is observed running an ethernet connection direct from music server PC to NAA, using a dual ethernet card in the music server, thus bypassing any switching.
Thanks debjit! I have SMS-200 with Curious USB pigtail cable, it's a great combination. But I'm still using stock PS for SMS200.fwiw, I have read (forget where) that an audible improvement is observed running an ethernet connection direct from music server PC to NAA, using a dual ethernet card in the music server, thus bypassing any switching.
