Is that a plastic laminate veneer? Looks like an bleached Zebrawood. Nice!
Rick,Thank you for posting this photo. What are the cabinet dimensions? How much does each speaker weigh?Oh, and what are the specs?
Awesome, I was hoping it would come with the 8 inch driver. What would be the cost in base finish ? thank you.
Add me to the list of people interested in this design. The Ceramica would also be a possible choice for me. When you get these finished it would be interesting to hear your take on the differences in the sound of the two models. For my application I think I need to go subwooferless, and use the speakers for movies as well as music. Based on the bass measurement, it appears that Vigore might suit my needs better. Haven't heard the Be tweeter, and I guess part of the reason you are using it is to save real estate to have a smaller box, but I love the Raal 70x20 in my Grandeur's. Would the Vigor with the Raal tweeter of the Ceramica be possible?
Rick,Are the cabinets sealed or ported?If they are ported, can you offer a slot port in the front instead of a rear port? Michael
I'll say it's a beast. Do you have stands to hold it?
Sure, we can build custom stands or even make a floorstanding version.
Rick, can you comment on:1. Which drivers were used. Others may be able to tell just by lookin' at 'em.....but I can't. Specifically, I was wondering if the tweeter was Be.2. Efficiency measurement. Is this 87dB @ 4 ohms? Just a guess.....was I close?Thanks, -dGB
