0 Members and 1 Guest are viewing this topic. Read 2472 times.
flm,If I am understanding you correctly then you will have one binding post after you use the straps. In the future you might want to biwire or biamp and need the other post. I hope you are understanding this correctly. I really don't think you will gain anything by taking out the other binding posts.In my showroom I use the RM-30c but in the vertical position and it is just a wonderful sound with clean ,clear dialouge with two RM-30m's with larger subwoofer and Ribbon dipoles for the surround. This ...
I think FLM is just confused by the stereotimes photo of the rear of the speaker (which I agree is rather small and looks like it has 4 sets of binding posts) and the rather large space btwn the top and bottom binding posts on VMPS speakers.Here's a detailed shot of the binding posts on my RM-40s:I believe the RM-30s have a similar binding-post configuration (the spacing between the top and bottom posts might be differe ...
flm,The "standard" wiring for all VMPS speakers is Monster 12 awg OEM for the woofers, 18 awg, stranded, silver plated copper for mids and 20 awg, stranded, silver plated copper for the tweeter.The Analysis Plus upgrade is just for the woofer wiring.I have had two folks ask for speakers with all Bolder cable internally. A pair of RM-40s and a pair of 626Rs were built this way. They used the 11.5 awg stranded NITRO speaker cable for woofers, 18 awg solid core for mids and 20 awg solid core for tw ...
