Anyone heard/ordered this amp? I know many Acoustic Reality posts are controversial, but at $499 this ICEpower amp (around twice cost of the JVC F10 on clearance at amazon for $230 shipped) seems worth the risk.
The specs are:
ear 202: Specifications per channel
• 200W @ 0.2% THD+N, 10Hz – 20kHz, 4 ohm
• 230W @ 1% THD+N, 10Hz – 20kHz, 4 ohm
• 290W @ 10% THD+N, 10Hz – 20kHz, 4 ohm
• 100W @ 0.2% THD+N, 10Hz – 20kHz, 8 ohm
• 130W @ 1% THD+N, 10Hz – 20kHz, 8 ohm
• 110dBA dynamic range, 200W @ 4 ohm
• THD+N = 0.006% @ 1W, 8.,1kHz
• THD+N < 0.2%, 0.1W – 200W, 4 ohm.
• Input Impedance = 11 kOhm.
• 79 % total efficiency @ 200W, 4 ohm.
• Upper bandwidth limit (-3dB): 65kHz @ 8 ohm, 45kHz @ 4 ohm
• Lower bandwidth limit (-3dB): 3,5 Hz
• Abs. output impedance: 10 mOhm
• CCIF Intermodulation distortion: 0.0005%, 10W/4ohm 14kHz/15kHz
• Transient intermodulation (TIM): 0.004%
• Damping factor: 4000, 100Hz, 8 ohm
• Minimum load impedance: 3 ohm
• Gain: 27 dB
• Output referenced idle noise: 90 µV
• Intelligent Universal mains select: 85 to 265 Volt AC
• Stand-by power consumption: 0.5 Watt per channel
• Size (w x h x d): 215mm x 65mm x 350mm
• Size (w x h x d): 8,4 x 2,56 x 13,8 inch
• Weight: 2,5 kg (5 lbs)
JVC RX-F10:
100 watts per channel x 2 (into 8 ohms, 40 Hz to 20 kHz, with less than 0.8 percent THD); 100 watts per channel x 6 (into 8 ohms, 40 Hz to 1kHz, with less than 0.8 percent THD)
