0 Members and 1 Guest are viewing this topic. Read 7888 times.
50ms - hard to distinguish the difference between that and 100ms (default). 250ms sounds much more "spacious" - less restricted soundstage than 50ms.
=> you have a bottleneck in your O.S. wich I suppose is not modified by you to play multimedia like 99.99% of users
I can't help but wonder if what's happening here is like tube amps and analogue playback (eg. vinyl). Objectively the DSD conversion adds distortion but the anomalies are not perceived as objectionable and in some material, the added noise and imprecision actually makes it sound less "sterile", "clinical", more "real" (conversely being in an anechoic chamber is disturbingly unreal due to the profound silence). It would make sense to me that some people could prefer DSD64 over DSD128 upconversion since DSD64 will give you more of that distortion. Even though the noise is ultrasonic in nature as measured off the DAC, nonlinearities in the playback system like your headphones and speakers (perhaps certain amps as well) could create audible intermodulation. Maybe for certain music, this could be especially beneficial.
ConclusionsIn virtually all cases, DSD adds significant processing to the music production chain. DSD absolutely fails to deliver a "direct" path between the A/D and the D/A. Any such claims are marketing spin. DSD offers no advantages over a conventional 24-bit 96 kHz system, and it fails to leverage the massively parallel architecture of modern converters. DSD cannot match the measured performance of a conventional 24-bit 96 kHz system. Conventional PCM systems provide the most direct and transparent signal path between the A/D in the studio and the D/A in the consumer's home. For these reasons, there is no compelling reason to pay extra for a DSD recording if a 96 kHz version is available. If the choice is between a CD and a DSD version, the DSD version may offer some improvement.Benchmark recognizes that there are many fine high-resolution recordings that are only available in DSD format. For this reason, Benchmark DAC2 converters are designed to directly accept 24-bit PCM or 1-bit DSD without adding any internal format conversions. This versatility makes it easy to play both high-resolution formats to their fullest potential.
