0 Members and 1 Guest are viewing this topic. Read 15289 times.
Anybody have an experience with the phono section of this preamp? Seems like everything I read is about it's digital playback abilities.Kevin T
I've ordered the Anthem STR Preamp and I have searched but not found if the STR Preamp supports iPod playback or not. One feature I take advantage of with my Oppo HA-1 Headphone amp/Preamp is iPod/iPhone support via USB. [...] I have all my CD's saved as Apple Lossless in iTunes and just plugging my apple device allows me to use the HA-1 DAC and bypass the iPhone or iPod DAC. Does the STR Preamp support this? I understand I would need an iPhone lightning to USB-B male or A to B adapter. The Oppo HA-1 works direct, if the Anthem doesn't would it work with an Apple CCK Lightning to USB Camera Adapter?If not, or even if it does, how about using a USB stick with FLAC? Would this allow playlists, albums, etc? I am a bit surprised there isn't a Type A USP connection on the front.
I will have an Oppo BDP-103 connected to the STR Preamp via RCA connections and I believe the 103 does support USB FLAC playback so if the iPhone/iPod/iPad digital USB connection doesn't work I have an alternative. Not sure what DAC I would be using but the 103 has a pretty good one regardless
I have both the Oppo BDP-103 and an Anthem AVM 60, which would be similar in many ways to the STR preamp. The Oppo's DAC is it's only weak spot, compared to a stand alone DAC the sound is muddled. I would use either a 75 ohm coaxial or optical cable from the Oppo to the Anthem for two reasons:1.) Hi-res audio into the Anthem stays Hi-res, the Oppo's RCA output is always 16/44.1.2.) Keeping the signal digital ensures the best results when using ARC Genesis, inputs can have multiple profiles so you can listen with ARC Off or On by using the remote.
Back in the napster days, the SACD standard was created as much for improved copyright protection as it was for improved signal quality. Unlocked SPDIF output was never available on any consumer device. I'm enjoying my STR preamp immensely. l like the single ended RCA preamp outputs better than the balanced XLR preamp outputs, even though my amp is fully balanced circuit, I use RCA adapters.I'm still just using Sonos' SPDIF coax for my digital content. Sonos is a notoriously high jitter source, which was audible on most of my previous DACs. But Sonos sounds fine on STR so I've not felt the need to setup a USB source even though I have a sms200. I hope it will sound even better.I deleted all but the 3 inputs that we actually use and labelled them with personal names (Radio, Sonos, TV) so my wife loves using the preamp for music and TV. She also immediately noticed (as did I) the big improvement in SQ over my old DAC. I tried ARC using the default automatic settings but wasn't too impressed. It "flattened" the sound. But I hadn't read the ARC instructions yet so I didn't do it correctly. I am still looking forward to playing with ARC and seeing what it can do when given the attention it deserves.
I tried the MM phono input, with my Clearaudio Concept with Maestro Wood MM cart. It was really rough going the first hour, it sounded really dead and flat, and the highs were very rolled off. I thought, "No wonder guys are panning it out of hand." But it did open up quickly and dramatically through the first few sides. After ~5 hours now it does sound pretty good, but still a little flat compared to my Vista Audio Phono1. Another 20 hours will tell.I did have to crank in +16dB of linestage gain to equal the output level of the DAC so I could compare SQ of DAC to phono. My cart makes 3.6mV.
It will be a couple weeks before I get my system set up. I'm also getting back in to vinyl. I have around 150 old LP's but they are old and were played hard during beer infused college and single days parties. I've invested enough that I'm afraid the rabbit hole is getting me. FLAC should work, I think the USB with the Apple Camera connector will allow a direct digital connection to my iPhone/iPad to play lossless. I can use my Macbook Pro, I hope I can find an optimal way to play CD's even if I need to add a dedicated transport.Thanks.
I finally was able to install my STR Preamp. The bad is the remote failed after 5 minutes as I was going through initial setup.I need to put my Harmony Elite Hub back in the cabinet. It has the STR Integrated remote codes in its data base but not the STR Preamp. DO you think they are the same?The good is I tested my iPhone connected to the USB port via the Apple Lightning to USB 3 Camera Adapter and it works just fine. I assume it is a direct digital connection using the STR USB DAC. Nice to be able to play my lossless files in the purest way. I'll try a USB drive next but need a USB A Male to USB A Female adapter. I also plan to test the Oppo BDP-103 via Coaxial.Also connected my VPI Prime Turntable to the MC Phono inputs and without any adjustments it sounds very good.
