0 Members and 1 Guest are viewing this topic. Read 15291 times.
Does that help?
Like you I prioritize good bass over pristine treble, and believe in optimizing room acoustics physically before applying RC.
My speaker's woofers cross at 120Hz with 6th order passive LP. It would be great to make that xo active. And with EQ I could seal the ports too.
Have you had any build quality issues or malfunctions? Some of the negative reviews on Crutchfield were related to technical problems, but that was a while ago. My dealer says Anthem support is excellent. He is premium dealer with Persona speaker line.
ThanksRich
It arrived today, and after only an hour of listening I am very impressed. No problem with tone or transparency... this is definitely a "high-end" audiophile component.
Funny i just saw this thread, as I've been looking into a Room correction solution myself. I have an older Anthem AVR in my video room/den and the sound is excellent. Since i also want a streamer I've been looking at the MiniDSP SHD and NAD C658...both which have pluses and minuses......
I bought it from Crutchfield and I've contacted them about the HT bypass issue. I'm just weighing whether I want to try another unit or just move on at this point. ARC really does make a difference.
[...]Already did the return on this one. I ordered the silver but am going to go with black on the next one (which I hope has the latest firmware and operates correctly!)
