Raidho XT-1 loudspeakers and which subwoofer
0 Members and 1 Guest are viewing this topic. Read 7302 times.
Rusty Jefferson
Re: Raidho XT-1 loudspeakers and which subwoofer
« Reply #20 on: 7 Apr 2021, 02:02 pm »
The Swarm may work well in a room that size. I heard it in a room more than twice as large. Each sub is placed where needed and not necessarily where you'd like it to satisfy aesthetics though. If you wanted to keep them inconspicuous as indicated in your first post, I'd probably use a couple Rel subs as mentioned earlier.
bferguson
« Reply #21 on: 7 Apr 2021, 02:52 pm »
Thanks for your comments Rusty, much appreciated
