NuTube preamp concept
0 Members and 1 Guest are viewing this topic. Read 15414 times.
happyrabbit
Re: NuTube preamp concept
« Reply #20 on: 29 Sep 2019, 04:10 pm »
Norman !
Thanks again for the insight and lovely commentary  :green:
Currently using the free software from www.4pcb.com.   It’s really a glorified paint program.  I have had 5+ years experience to learn most of its tricks..
The cost difference between a 4 layer vs 6 layer pcb isn’t soo great plus it’s a DIY project.  I ended up with sig/gnd/pwr/pwr/gnd/sig configuration.  The two ground planes are tied together.   The plane pours are tied to the input ground.  I guess it’s more of a mixed signal configuration..   The input & output signal are on the top level and the bottom level contains everything else.  The power planes are sandwiched between the grounds.   This approach is new territory for me.
https://hobbyking.com/en_us/vibration-damping-balls-300g-red-8-pcs.html
The Microphonic Issue..  you might have noticed the mounting holes are huge...  I plan on using  ‘damping balls ‘ and placing the PCB in tension.  The case mounting points are offset  to achieve  a ‘mildly tensioned’ PCB..hopefully   This approach is similar to solutions found  on drone camera mounts.  I will also add a 2mm silicone pad to the bottom of the nutube with mass loaded vinyl on top.
Dwight
« Last Edit: 30 Sep 2019, 09:33 pm by happyrabbit »
happyrabbit
« Reply #21 on: 3 Oct 2019, 01:50 am »
1st board built !
happyrabbit
« Reply #22 on: 4 Oct 2019, 04:10 am »
Please note da Glow  8)
happyrabbit
« Reply #23 on: 13 Oct 2019, 02:48 pm »
My next attempt @ da nutube.  No more variable plate load.   Too many issues  :duh:   Going to place an Intact Autoformer on the front end for attenuation.   Moved the layout around to improve cable routing.  Hopefully the muting shunt will actually work this attempt.   No more unprotected mosfets for me.  :wink: Also replaced the b+ op-amp buffer with an 7h + 220uf filter.  Similar to the Grid configuration.  The 10uf electrolytic blocking cap has been replaced with (2) 4.7uf 50v Rubycon Mu Series. Curious about the sound.  :scratch:
http://www.intactaudio.com/atten.html
« Last Edit: 29 Nov 2019, 01:26 am by happyrabbit »
aldcoll
« Reply #24 on: 13 Oct 2019, 09:40 pm »
Please note da glow)
  I only see 1 side glowing,  is that a photo reason or??
I am interested as all getup.
Alan
happyrabbit
« Reply #25 on: 13 Oct 2019, 10:25 pm »
Alan,.
One channel per board.   This is not a minimalist approach.  :green:
Couple weeks out on the next board.
Dwight
happyrabbit
« Reply #26 on: 24 Oct 2019, 03:13 pm »
Round 2..    also changed the input transformer from 1:1 -> 2:1 to lower the gain from 12db to 6db.
happyrabbit
« Reply #27 on: 29 Oct 2019, 12:18 am »
« Last Edit: 30 Oct 2019, 12:39 am by happyrabbit »
happyrabbit
« Reply #28 on: 7 Nov 2019, 03:31 pm »
Round 3..
* 4 layer PCB instead of 6
* removed the rubycon mu film and added amtrans amcg  (dc blocking)
* 4 pole mundorf replaced with a heavy duty common mode / diff filter.
* added a cascode ccs to the Jfet voltage follower.
Also ordered a new case to support the intact autoformers.
happyrabbit
« Reply #29 on: 15 Nov 2019, 02:41 am »
Intact 47 Position Autoformers.  Thinner case.   Having issues with filament noise on the latest Build.  CCS is appears unstable with this Nutube.  Audible hiss..ugh  :o   Ordered another tube.   I noticed a couple people on diyaudio stating ‘ hiss ‘.  I thought 💭 grounding issues. Maybe not.  See attacched
« Last Edit: 16 Nov 2019, 05:28 pm by happyrabbit »
happyrabbit
« Reply #30 on: 17 Nov 2019, 01:00 am »
It’s finally done and operational.   :green:   Glad it’s over 👍.  Tremendous amount of effort and $$$$.
Dwight
« Last Edit: 18 Nov 2019, 02:25 am by happyrabbit »
happyrabbit
« Reply #31 on: 11 Dec 2019, 04:37 am »
da Luv is On !    latest version.   noise finally gone !   da nutube is the bomb dot com  :thumb:
Clarity CSA for the dc blocking cap.  Gotta luv purple  :green:
Back to a op-amp buffered plate load.
Common mode & diff filter for dc supply.
Reconfigured CCS for lower filament noise.
Leaded solder..  much easier soldering into the GND plane.
« Last Edit: 18 Dec 2019, 03:45 am by happyrabbit »
