0 Members and 1 Guest are viewing this topic. Read 320 times.
Kevin Spellman
  • Guest
« on: 17 Apr 2018, 07:17 pm »
Hi--I am user "Fatawan" here, and I have forgotten my password. I did the reset request, but unfortunately I didn't receive the email which means it went to some email I stopped using long ago(maybe valueman@yahoo.com or something similar?). Is there any way to reset this account rather than opening a new one?
  • All Tweeters look like a target, then shoot them!
Re: Login
« Reply #1 on: 18 Apr 2018, 01:01 am »
OK a admin will see your account soon.
richidoo
Re: Login
« Reply #2 on: 18 Apr 2018, 01:05 am »
Kevin, what is your current email address?
I will manually update your email address so you can request a password reminder or reset.
(Then I'll delete your email address from this thread after you get fixed.)
richidoo
Re: Login
« Reply #3 on: 18 Apr 2018, 02:40 pm »
Your email is changed.
