0 Members and 1 Guest are viewing this topic. Read 6022 times.
Hi James,Are the speakers still available in gloss white?
Does any wood grain show through the paint? Thanks
wow...it seems smaller than my 4BSST2. is that just my imagination...or is the new 24B3 a little more slender..?T
James,does the 24B has the same dimension (depth) as the 875HT amp? if yes, then this amp is indeed smaller (height) but it is also much ''deeper'' than a 4B. al.
HiYou can do that if you want but the current version shows no grain.james
