jr filter
0 Members and 1 Guest are viewing this topic. Read 1382 times.
ryno
jr filter
« on: 4 Jan 2005, 01:41 am »
Hello
I'm ready to order your exodus power filter and have a question. If the 2 filter and high power parallel is chosen, do you get one filter on one outlet pair, the second on another pair, and the parallel on the third? What is your recomendation for a system with a transport, digital eq, DAC, pre, and amp. Thanks in advance, Ryan Olson
Kevin P
    • http://www.diycable.com
jr filter
« Reply #1 on: 4 Jan 2005, 08:45 pm »
Ryan,
The web site needs to be updated.   We have the ability to build the filter with dedicated filters on each outlet.   We also have the ability to provide a DC filter on one outlet if you have power amps with buzzing transformers.
What I recommend is a filter for each outlet.   That way you isolate components from each other.   The high power parallel filter isn't typically needed unless you have a poorly designed power amplifier.   The impedance added by these filter networks is minimal and if you have problems due to them it is more likely an issue with the size of the power supply on the amp.
Cost on a three filter network version is $232 since we have to add an additional PCB.   We can add the DC filter to one outlet for another $10 which can be nice if you have humming transformers due to DC on the AC line.
